Threads: 25
03-18-2019, 09:02 AM
(This post was last modified: 03-18-2019, 09:05 AM by Mitja GOLOB.)
Hello!
I use the CAD / CAM method for robot programming. When I generate code for a robot controller, I see that only movL commands are used.
example:
movel(p[0.601219, 0.202453, 0.146580, 0.000000, 2.902453, -1.202235])
movel(p[0.601305, 0.202425, 0.146607, 0.000000, 2.902453, -1.202235])
I would expect that moveP will be used. Why it only uses moveL commands?
Thanks for the reply.
Mitja GOLOB
Threads: 25
Hello!
It would really help me if anyone could answer the question. I can't find any documentation that would nicely describe the use of the moveP command (if it is even possible to use the moveP command).
Mitja GOLOB
75
Hi Mitja,
The use of MoveL vs MoveP command is only managed by the post processor. You can go in the post processor and simply change the variable "USE_MOVEP" from False to True.
Your program will then be generated using MoveP instead of MoveL.
Have a good day.
Hi, I am trying to use the MoveP post processor, but if so the robot stops the programm after 1 sek. With the general Universal Robot post processor everythings is fine but the curves are executed quite poorly. The robot shivers constantly.
Can somebody help?
Best regards
Ok it was simply a speed problem :D
But I don't really understand, why the moveP post processor causes the programm to stop immediatly...
