What happened to Mastering Program?
See link: Robot Calibration (Laser Tracker) - RoboDK Documentation
This is exactly what I need at the moment, a program to send my arm to the proper home position so I can unmaster and remaster it. Did this move somewhere or did we lose it entirely?
I'm using a machinist's caliper otherwise, and it is not enough. A 4-point TCP through the pendant has a mean error of 3mm.
You should select Calib. param. (calibration parameters), then, select Mastering and OK to see the mastering option.
(08-11-2022, 06:17 AM)Albert Wrote: You should select Calib. param. (calibration parameters), then, select Mastering and OK to see the mastering option.
Works perfectly. Thank you Albert!!
3 Guest(s)
