Kuka - RoboDK Integration
Hi All :),
Trying to connect a Kuka agilus KR6 r900 2 robot (with KRC4) with roboDK
I have followed all steps defined in this manual - Link
Achieved communication with the robot and have successfully retrieved it's position
Currently stuck trying to run a program from roboDK on the robot.
Referring to this line (last line in the manual) "Manually start the “RoboDKsynch.src” program to make the robot behave like a server that responds to move commands coming from the PC."
I've tried to manually start the program from the teach-pendant or directly from the controller (via screen & keyboard..) I'm constantly receiving error "KSS01324 .src not available"
Tried changing to automatic & external operating modes and also restarting the controller.
Would appreciate any suggestions !
Guy
Hi Guy,
It is the first time I see this error. Something may be wrong with the configuration of the controller.
Are you able to run any other programs?
Did you purchase the robot directly from KUKA?
Yes - Robot was purchased directly from Kuka
Yes - Able to run other programs exported from roboDK with kuka_KRC4 post processor, experimented with several (with some caveats that could be related to the simulation programed)
Is there any tale telling files I can attach that will shed light over this ?
Guy
Hi Guy,
Did you declare the global variables as described in the procedure?
(the $CONFIG.DAT file)
Can you provide more information or a screenshot about the error?
